Building a CPU , need help checking parts & Give suggestions
enmakun
Hi there peeps! :) I'm new here. Am planning to build a CPU from scratch soon , and iv'e roughly researched on the parts I plan to get. But before that I just wanna double check if all is compatible and good for mid-high end gaming computer?
If yes please say so , and if not, please tell me any suggestions!
Btw my budget was orginally 1.6k SGD. and i probably overshot alr. If you have any idea where i can cut edges to lower the cost, do share as well! All help is much appreciated :) Thank you!.
CPU:
Intel Core i7-4790K 4.0GHz Quad-Core Processor
Cooler:
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard:
Gigabyte GA-Z97X-SOC ATX LGA1150 Motherboard
Memory:
Corsair XMS3 8GB (4 x 2GB) DDR3-1600 Memory
Hard-drive:
Samsung 850 Pro Series 256GB 2.5" Solid State Drive
Graphic Card:
NVIDIA GeForce GTX 970 4GB Video Card
Case:
Cooler Master HAF 932 Advanced ATX Full Tower Case (if possible dont change this cuz it looks really nice HAHA)
Power Supply*:
Enermax REVOLUTION X't 530W 80+ Gold Certified Semi-Modular ATX Power Supply (is this one ok? im worried for my new CPU cuz i'm unsure of the Watts)
OS:
Microsoft Windows 8.1 (OEM) (64-bit)
Optical Drive:
Samsung SH-118CB/BEBE DVD/CD Drive
(I'm aware some cases/motherboard/cpu comes with integrated fans or power supplies or whatsoever but i think buying it separately would be much safer and better (?))
Thanks in adv for the help! :)
MoneyFace =p
Red and black themed. :)
CPU+MB: Intel Core i5-4690K + ASRock Fatal1ty B85 Killer @ $417
WC: Corsair Hydro H100i @ $159
RAM: G.Skill RipJaws-X DDR3-1600 CL9 8GB Dual Channel Kit [Red] @ $114
GPU: Sapphire R9-290X 4GB Tri-X OC @ $405* (Lazada Singapore)
SSD: Lite-On S900 256GB @ $138
HDD: Western Digital Blue 1TB @ $70
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: FSP Aurum S 500W [80 Plus Gold] @ $89
CASE: Corsair Carbide SPEC-02 @ $84
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $110
Total: $1607
Optional:
CASE: Sharkoon T28 [Red] @ $73
Buy others at Tradepac, #05-18.
*Price after Lazada discount (TBA later)
Cooler Maser HAF 932 Advanced is a full tower which is very huge, as compared to the items to be installed in the PC.
I will recommend the following instead:
Sharkoon T28
royfrosty
First of all thank you Vijay for moving it to this thread.
As for TS, the parts you listed definitely will exceed your $1.6k.
Few things to note before reading anything below.
1. There is no need for an i7 and a Z97 motherboard in terms of gaming. Its just spending more for the features that you might not need at all. The difference in board categories are much more of a different specific features that you need in a mobo, primarily it is to connect all the devices together and work as a PC. It does not bring you any performance value if you buy a z97 mobo. Z97 carries a full features such as overclocking RAMS, CPU and other overclocking features. Also with things like more power phases and also capable of going multiple graphics. Most of the people here either fall into the category of either H81 or B85/H97 only. Not unless you are a serious gamer and wanting to spend top dollars on extra GPU and high horsepower CPU.
2. i5 vs i7. In terms of gaming performance, this 2 brings negligible performance gain. The amount of performance gain in gaming is only a single digit FPS. NOT unless it is a super high end gaming that will bring down the entire PC specs to their knees. Those game usually rarely comes out. The i5 is the same as the i7 quad core processor, just that the i7 has slightly higher base clock, more cache memory and Hyper Threading. Most games dont utilize even more than 2 cores. At most 4 cores 4 threads.
3. Solid State Drive (SSD). This usually people will buy popular brands such as Intel, Crucial, Samsung, Plextor/LiteON. And usually they wont go for the most expensive model out there. Like the performance gain from a Samsung EVO 850 to a PRO 850 has no visible performance gain. You can't see it with your naked eyes. Not unless you benchmark it. Usually SSDs are fast, and they are hard to compare for daily usage, as it is split seconds away.
4. PSU, never SKIMP on PSU, its the heart of the system, and its something serious to pay attention about. High wattage =/= good. Get what is needed for your PC. Not getting surplus wattage. The moment you skimp on PSU, and when it "POPS", a chain reaction to all your PC components will go down together.
So here are the list for your 1.6k rig.
MSI H97M G43 + i5-4460 ~ $363
GSKills Ripjaws 1600mhz 2x4gb kit Blue ~ $115
WD Blue 1tb ~ $70
LiteON S900 256gb ~ $138
MSI GTX970 4gb Armor Edition ~ $509 (Price before discount, wait for participating cards weekly for attractive price cut at Lazada.sg)
FSP Aurum S 80+ Gold 500w PSU ~ $88
Sharkoon BD28 Chassis ~ $74
LG DVD Drive ~ $21
Windows 7 Home Premium 64bit OEM ~ $115
Total ~ $1493 before lazada discount. Buy at tradepac unless stated.
enmakun
Moved to correct forum.
Sorry! Didn't notice haha.
Total: $1607
Optional:
Thank you for the case suggestions! :)
WD Blue 1tb ~ $70
LG DVD Drive ~ $21
Thanks dude! by the way, you got any ideas on a good Monitor? that's not-that expensive. All the "budget" gaming Monitors i come across range from 150~400 USD which is wayyyyy too expensive.... and I heard it affects the graphics so i'm kinda stuck here...
royfrosty
In general monitors sold goes by the resolution. 1080p 1440p 1600p and last 4k.
"Gaming" monitors are used to market it to gamers. But primarily its still a monitor. Just what they added features inside such as faster response time, and higher refreshing rate of up to 144hz. Gsync and Freesync etc.
Monitors are then classified under certain categories such as IPS panel, PLS panel (same as IPS but Samsung called it PLS), VA panel, and last TN panel.
Among our hardware communities here we would prefer IPS/PLS panels here. As the color richness and good angle viewing is something most of us here like it.
To some they sacrifice colors for a faster panels such as 144hz TN panel.
For the start i would recommend you a few of Dells 23inch and 24inch monitors.
S2340L is the cheapest 1080p monitor out there available. The downside of it is its glossy panel surface and has only HDMI input. Its going for $198 and below.
P2314H is slightly more premium over the s2340l. With matte screen surface and has various inputs. Comes with 5 years warranty. And yet does not break the bank as it is sold at $248 and below.
Slightly more expensive and more premium panels are the U2414h or U2415h. Both out in the early 2014 and late 2014 respectively. Both spotted with bezeless sides and extremely sleek monitor. Comes with all the multi inputs and usb connectivities, able to tilt, swivel, and pivot. Comes with a 5 years warranty and going for $348 and $378 respectively.
