Building a cpu with $1000
Jaiw3i
Please kindly recommend me the best setup as of current market with $1000!
I already have:
- 1TB Sandisk SSD
- CPU Case
Games i play:
Dota 2, Battlerite, No man’s sky, PUBG
Im building purely for gaming and performance, do not need a extra hard drive.
Please recommend me any store in SG that does a good work and trustable.
narkizy
Amd 2600/2600x is sufficient. Any shop that recommends u an intel chip, run far far away, you're getting overpriced.
2060 or as low as a rx 580/1060 is sufficient.
_DeS__
I already have:
- 1TB Sandisk SSD
- CPU Case
Games i play:
PCT / Fuwell / Infinity Computer
watzup_ken
I don't think the shops will assemble for you if you don't get full set from them. Also it makes no sense for you to lug your casing down for them to do the installation since you mentioned you don't need to get a new case.
zellas
Hmmm... I would recommend the following specs for you. Total cost ard $1010
MSI B450M Bazooka Plus with Ryzen 2600
Klevv Bolt X 3200MHz CL16 (2 * 8 GB)
Zotac GTX1060 6Gb Amp!Edition
CM MWE Gold 550W 80+ Gold Modular
Tecware Nexus Tempered Glass Black
You can ask the shop if it's ok to fix the SSD for you since most parts are brought there. Shouldn't be a problem u should get a new casing too.. less trouble carrying things down unless you want to DIY fix at home.
shadow84
Your only choice is to bring your existing parts with you to sls, buy remaining parts frm any lvl 4-5 shop then bring all to PC care & Solution and ask Nigel for assembly assistance at a fee.
njcmaple
Can consider getting a used gpu as prices have dropped a lot due to rtx series
And so simple to install
vironix
just ask nicely. they will help u fix the ssd into your case one...
at most pay $10 lor
MagixuserII
haiz, recommend you this you dont want.. if you dont want the case ask for more discount $750-800. Not mine btw, just giving you the option. Slap an AIO CPU cooler and your good to go on any games from 1080p to 1440p.
Cpu: intel i5 8400 6core 12 threads 2.8ghz turbo boost 4.0ghz
Motherboard : MSI Z370 krait gaming motherboard
Gpu : gigabytes g1 gaming Gtx 10708gb (1 year plus more warranty)
Rams: Corsair vengeance 2400mhz 16gb rams
Psu:EVGA 750w gold psu
Case : Razer s340 case
https://sg.carousell.com/p/i5-8400-...ype_suggest&ref_suggestionSource=type_suggest
yusoffb01
No need recommend you anything i guarantee you already receive many pm from ppl wanting to "help" you
