BUILDING FROM LEFTOVER PARTS
wtfwfs
HI ALL
I HAVE THE FOLLOWING PARTS LEFTOVER FROM MY PREVIOUS UPGRADE.
1. ASUS Z87-A MOBO
2. x4 IDCOOLING FANS
3. 23 INCH SAMSUNG MONITOR
4. 120GB SSD,
what would be the cheapest way to build a pc that can support bF4 around medium settings
dont mind i5 and below and i dont mind doing overclocking
dgenex
Your motherboard supports LGA1150 CPUs only, meaning CPUs like i5-4690k, i7-4790k. List can be found here: http://www.cpu-world.com/Sockets/Socket_1150_LGA1150_H3.html
These CPUs not sold at shops in SLS anymore, so if you want to reuse that motherboard have to find CPU from somewhere else.
Excluding cost of CPU and/or Mobo,
Case: Tecware F3 ($49)
HDD: WD Blue 1TB ($72)
PSU: FSP Hexa+ 450W ($59)
GPU: Palit GTX1060 3GB ($275)
RAM: 8GB Kingston 2400MHz ValueRAM ($89)
Total: $544 (Prices from PCThemes pricelist)
Suggest just getting a new motherboard+cpu
ASUS H110M-A M.2 D4 + G4560 ($193)
https://www.youtube.com/watch?v=tHzMaJRuzsg (GTX 1060 + G4560) about 100 fps on Ultra at 1080p. BF4 not a very demanding title to be honest
spiky0180
Your mobo still ok if you can find an overclockable i5 from IT garage. But it is ATX form factor, so you have to find an ATX case. The rest can go with what is recommended. If you have the budget, get a better PSU and 16gb of ram.
dgenex
This is correct, didn't notice its ATX board haha. F3 case can't fit.
The options I recommended is just the most budget if you are really intent on saving money. Agree with what spiky said as well with regards to the upgrades :s13:
Koenig168
G3258 - about $50 second-hand
2 X 4GB of DDR3 - about $40 to $50 second-hand
wtfwfs
ty for the input
one of the reason for building it is i want to try out overclocking
and the other one is because my z87a board keeping dust, like waste if dont use because ive "upgraded' or you can say downgraded to itx
darkazelf
If you can get a 4670k cheap, a decent cooler and psu then go for it. Cheapest would be G3258 with stock cooler, can probably get up to 4.2ghz.
Some games might not like 2 cores though, in that case might be better going with locked i3s which has hyperthreading at least.
Sent from ZUK Z2131 using GAGT
