Building my first computer part 2
tigerwoods
plan your budget on the most important parts first like CPU, gfx card, RAM, PSU and ssd these are the parts that will affect performance.
OceanEleven
GTX 1080 is still going to be too expensive for me, even if i go for the cheaper brands(which i don't mind at all). I don't care at all for aesthetics, only for the performance of the computer.
Guess that you have to look out for Q10 sale. I managed to slash 200 plus off GTX1080 when I build my rig and run with my 144hz monitor and max setting.
Bite the bullet a little and go for the best GFX. Afterall, this is what you will be looking at.
singupingu
CASE: Tecware Edge ($69)
MOBO+CPU: MSI Z270 SLI PLUS + i7-7700K ($753)
CPU COOLER: Cryorig H7 ($65)
RAM: Corsair Vengeance LPX 2666MHz 2x8GB kit ($184 after $15 off via Lazada)
PSU: Superflower Leadex Gold 750W ($164.70 after 8% off via Lazada)
SSD: PNY CS1311 240GB ($109)
HDD: WD Blue 1TB ($72)
GPU: Palit dual GTX 1070 ($524 after $15 off via Lazada)
OS: Windows 10 OEM (<$30 from Carousell)
MONITOR: Samsung 24"Curved Monitor C24F390F 1080p 144hz ($285 after $15 off via Lazada)
WIFI: ASUS PCE N15 ($59)
TOTAL: $2315
Prices quote from PC Theme or otherwise stated
After shop discount a little bit, and the windows 10 which is cheaper, and using Shopback for lazada for 1.5% rebate. About a little lesser than 2.3k. I don't know where I can skimp on anymore.
Sent from Overpowered Phone Mark III using GAGT
Eternit
TOTAL: $2315
Hey I wanna know how to get the $15 discount from Lazada? dont seem to find it on the site...
singupingu
Code: CITIWONDER (sat to mon)
using CITIBANK cc, first 400 customer will have 8% discount, capped at $15.
Code: DBSFIESTA (fri)
using dbs or posb cc, first 700 customer will have 8% discount, capped at $15.
All buy separately when it is about to hit 200 bucks to get maximum discount.
tigerwoods
TOTAL: $2315
are you sure Samsung 24"Curved Monitor C24F390F is a 144Hz monitor not 60Hz?
Can provide your source?
singupingu
My bad. I've checked. The monitor is not 144 Hz. Zzz lazada title misleading.
Sorry.
Update:
MOBO+CPU: MSI Z270 SLI PLUS + i5-7600K ($596)
TOTAL: $1876
My suggestion is not to take 144hz monitor. You can do a quick search at lazada and qoo10. One can easily fetch 500 bucks.
The remaining budget you find a decent 60hz 1080p monitor which you're happy with.
tigerwoods
get a 27" IPS 1080p 60hz monitor is awesome too, and the color will blow away all those 144hz TN monitors.
shadow84
Drop the cpu to non-K and mobo to B250 and one can get a better case and maybe 500gb ssd.
Michael_Scofield
sorry hijack thread, what's the current budget 60hz gaming monitor in the market? Se2417hg? Any news on new monitors that would come into the market...
singupingu
Ghostyjangle
Sorry.
Update:
TOTAL: $1876
But i read Palit reviews and they said the card's cooling isn't as good. Will that be a problem?
NiuNaiFen
Sorry to hijack the thread.
I do wan to build a rig something like yours. Just casual gaming need onboard wifi and a FAST respond comp. will the build below be ok:
i7 7700k or i5 7600k (I might or might not OC)
Asus z270e
Asus GTX 1060 strix
16 GB RGB 3200 gskill
Corsair H100i
Samsung 960 evo 256 or 512
Intel 520 480gb - recycle
Seasonic x760 - recycle
Corsair 570x
Pls assist thanks
singupingu
Asus z270e
Asus GTX 1060 strix
Corsair H100i
Corsair 570x
Pls assist thanks
Dude, your budget for other stuff is so jacked and you go for gtx 1060? How is that justifiable? Lmao.
i7 if got budget, i5 if budget is limited. Samsung ssd is expensive.
Ocz TR150 or pny cs1311 is more than adequate.
Get a GTX 1070 at least. Whichever model is fine as long as the appearance and budget is okay for you.
Consider according to your budget, start with gpu, then cpu and finally the ssd.
NiuNaiFen
Haha cause only some casual gaming that all that why chose 1060.
Ended up having this:
i7 7700k
Asus Z270E
G.Skill RGB 3200 2X8
Asus GTX 1060 Strix O6G
Samsung 960 evo 500GB
Intel 520 480GB
Seasonic X760
Corsair H100i V2
Corsair 570x
