Building my first ITX PC / or Mini ITX
hotyrole
Hi Guys
I am hoping to build a small form PC , mini ITX with a budget of $550
or just a $550 for a "normal" PC
Can anyone help me with this project ?
To see how much can my budget stretch to design one of the price worthy CPU
for reference
500 buys a videopro i3 set with everything
Jian19
Normal usage ?
No OS thou
Jian19
If u dun mind micro atx then
i3-3220 + Asrock b75m dgs ~ $199
Adata 4gb ddr3 ~ $43
Wd blue 1tb ~ $76
Fsp hexa 500 ~ $58
CM n200 ~ $52
$428 buy and DIY @ tradepac ask for discount ~ if not sure how to DIY can bring to gs shop ask him help u assemble @ a fee
Still have some budget for either...
OS ? ~ $115
Gfx ? ~ Powercolor 7750 @ $85
Ssd ? ~ plextor m5s 128gb ssd ~ $128
Ark Law
Hmm, also interested at looking at building a miniPC in the next month, with similar budget (less than $550). Am thinking an Intel NUC would serve me well, but still acceptable/open to any ultra small ITX rigs that would be possible within budget as well
Already have laptop ram that I could use for NUC tho...
Jian19
Gigabyte brick ?
hotyrole
is Asrock Mobo good ? should I pay a little more to better one ?
Wd blue 1tb ~ $76
Fsp hexa 500 ~ $58
CM n200 ~ $52
OS ? ~ $115
hotyrole
sounds good.
where else do they sell DIY Set, and of good service(without carrot chopping) in Sim Lim ? Or anywhere else u know ?
so far i only know
-VideoPro
-Fuwell
-Bell Sys ( still around )
-TradePac
-BizGram ?
Anywhere else ?
MoneyFace =p
Best of all worlds~ :D
CPU+MB: Intel Pentium G2130 + MSI B75IA-E33 @ $183
RAM: ADATA Premier DDR3-1600 CL11 4GB @ $43
GPU: Sapphire HD 7750 1GB [Low Profile] @ $145 (PC Themes)
Giving you enough punch for max quality, smooth experience on all light gaming titles.
HDD: Western Digital Blue 1TB @ $76
CASE+PSU: In Win BM650 [Black] + Powerman IP-AD180-2 180W Flex ATX [80 Plus Bronze] @ $109
System power consumption will only hit 120-130W at most, leaving relatively comfortable headroom and moderately audible system.
Total: $556
Buy others from Tradepac, #05-19.
hengheng220
bro imo i think that the reason to top up to pay for a more ex mobo is because the more ex one offers the specs you need or that because you likes the design of the mobo such as the dragon on the msi gaming board. hahaha honestly abit regret buying my msi mobo just because i like the dragon when i can save up on buying a normal mobo but thats what i think, might not apply to you~~
hotyrole
thanks bros.
I realised i was referring to a micro ATX instead of a mini ATX
Size of a micro ATX > mini ATX
Any price worth Mobo/CPU bundle for this genre and build ?
@ thanks Jian19 for the recommendation
anyone else ?
Kyo_kusanagi86
My ITX build based on Intel 3rd gen.
CPU: I5 3470 3.2 GHz
MB: GIGABYTE H77N-WIFI.
RAM: Cosair Vengeances 16GB CL9 1600mhz
GPU: Leadtek GTX 650 ECO 1GB DDR5
HDD 1: Western Digital RE4 WD2003FYYS 2TB 7200RPM 64MB WIN XP
HDD 2: Seagate Barracuda ST2000DM001 2TB 7200RPM 64MB WIN 7
ODD: LG GGW-H20L HD-DVD/BLU RAY Writer
PSU: Seasonic M2II 520W Modular
CASE: LIAN LI PC-Q08B Black Aluminum Mini-ITX
hotyrole
is this within the 500 budget ?
just to check with bros if miniITX system would experience potential heat/lag problem ?
Jian19
If u use with a gfx that loads with high temp then might have heat issue...if just using onboard then no problem
I suppose it's for daily usage and no gaming for ur system ?
hotyrole
yes, just daily office usage, occasionally video and stuff
is there any gfx that load with low heat
Jian19
7750 low profile
But i Dun think u need a gfx... onboard should be fine for u
wtfh4x
Confirm cannot inside $500 la. My ATX with worse specs than that already $800. Dunno why he post here for what. Show off e-penis only.:s22: Whether overheat or not depends on your casing and the CPU and GPU lor.
Can try a small mATX rig
i3 3220+B75M-DGS ~$200
8GB DDR3 Kingston ~$90
Sharkoon mATX $50
FSP 300W ~$40
1TB drive ~$80
DVD ~$22
Pricing all estimate cos im too lazy to check. But should be close to $500.
If you want to play game then i3 change to a Pentium and cut the RAM to 4GB. The savings can get you a Powercolor HD7750 ~$90.
