Building my first PC pls help
alexengqc
Mainly to play overwatch,bf4 and lol
Intel Core i5-6400
MSI H110M-PRO-VHL
ASUS Expedition Geforce GTX 1050 2GB GDDR5
Kingston HyperX Fury 2400MHz C15
Samsung 120GB 850EVO SSD
Toshiba 500GB 3.5-Inch Internal HDD
CM Elite Power 460W
Windows 10 Home 64Bit OEM
Tecware F3
Total cost $1071
can help me check if there is anything wrong with this build
Koenig168
MB+CPU - i5-6400 is one generation earlier. Since you are building a new rig, might as well go for Kaby Lake. AMD Ryzen is looking better at the moment but the lower tier CPUs are not out yet.
GPU - suggest you go for a cheaper brand like Zotac or Palit and bump up to GTX 1060.
HDD - suggest 1 TB minimum. Difference in cost is not much.
PSU - nope. Don't skimp on PSU. Suggest Superflower and at least 500W.
Windows 10 - can get it off Reddit for much cheaper.
alexengqc
i want to get a newer CPU and mobo too but im running on a budget, is there other alternatives?
ChaoAhGua
get all ur parts online.
i just build a PC about 900+ to 1k
i5 6500 with gtx 1060 Amp edition
the rest of the parts similiar to yours and with 24inch dell monitor.
just have to make sure you wait for the right time to get all the coupons from Qoo10/lazada
alexengqc
Is lazada/qoo10 cheaper than SLS?
