Building Ryzen Pc Parts
silentears
Hi first time builder here. Please recommend parts and prices.
Budget : 2k can stretch to 2.2/2.3k
Usage: eSports, watch movie, want to try AAA game titles if possible
Hope to try 1440p gaming? if can optimise budget
Specs as follows:
Processor
AMD Ryzen 5 3600 6-Core 3.6 GHz $303 OR
AMD Ryzen 7 3700x 8-Core 3.6 GHz $528
MOBO
B450 Tomahawk Max (OOS) $175
RAM
Corsair Vengeance LPX 16GB (2x8GB) DDR4 3200MHz C16 DIMM $142 OR
CORSAIR Vengeance LPX 32GB (2x16GB) DDR4 3200MHz C16 DIMM $249
Graphics
Cheapest 2070 618 OR
Cheapest 2070 Super 749 OR
Wait for After-market 5700 Xt $629
PSU (Gold rated/ Full modular? , not sure how much W needed) $169
Water Cooling OR Air Cooling (e.g Noctua) $200
Monitor (144hz, TN for better brands or choose Acer IPS/ Prism IPS) $300- 400
Choose 1080p 27 OR 1440p 27inch
Choose TN OR IPS
Currently owned: 60hz Dell IPS U2417
Case
Fractal Design - Meshify C ATX Mid Tower Case $150
Hard-disk (reuse) from current pc (Crucial P1 500GB NVMe PCIe 3.0 x4 M.2 Internal SSD) + 1 SSD (sata) + 1 WD Black (sata)
Thanks
SkyShroud
3600 and 3700x perform the same in games, so if you got no need for extra cores and threads, just go for 3600
32gb vs 16gb. I would say games run with fine with 16gb. Haven't seen any esport games that use much ram exceeding 16gb or even 10gb. The only games pushing that limit usually is those 4x title where people go max map size etc and cities skylines w/ tons of mods.
Graphics go hand in hand with your monitor. Since is esport means at least 144mhz for fps games thus you will want gpu able to go 144mhz for that monitor. Again, you can only decide after you decide your monitor.
PSU: EVGA G+ Gold 650w or SeaSonic Focus Plus Gold 650w are good options. You can get better ones but those are the minimum I recommend.
A top air cooler outperform top water cooler, unless you go custom loop.
Monitor. For esport, some would say 24inch and not 27inch, due to peripheral vision.
Problem with 24inch is there is no ips panel at 144mhz. I would prefer ips because of the better colors. As for response time, is better to read reviews for ghosting than trusting the response time itself.
StationA
16GB is enough for games. I am using 32GB never see the memory usage over 16GB in games.
dont use any TN screen the color invert is very uncomfortable. its more important for color instead of 144Hz over 60Hz.
andymarsh
For the monitor, I wonder if you have considered ultrawide for movie watching and productivity (side by side editing).
Acer Predator x34p (ips) and z35p (va) are both pretty good. Of course, the price is another tier higher. Find some time go to courts or something and get a feel of the size
silentears
thanks will try to check it out.
