Bus give way box
sinistral
Depends if you are referring to the dedicated stop line for bus to come out from bus stop. Just a matter of courtesy to give way to buses regardless.
Otherwise, don't need to bother what the rear is doing.
BigMonkey
driving have to be thick skin and patient. A lot of driver are impatient. Similarly, i also encounter others, green light once lit, they start to honk. left turn arrow lit also honk. turn right red arrow also honk. Seems like they only buy car with honk and it didn’t come with complimentary signal lights as you will see them weave in and out of traffic after the traffic lights
zzzzzzz
mandatory give way if its a box with arrow coming out from bus stop
just wind down the window and raise your arm to the fella behind (the horn simi horn gesture)
mel1888
The law is u need to give way, so screw the honker.
For me, if i see bus still has its blinkers on i maintain the lane.
If its right arrow is lit, prepare to stop b4 box else switch lanes.
But nowadays, most bus drivers use common sense and dun simply chiong out. They wait for car to stop b4 exiting.
Caution, if u wan to stop, dun e-brake. Saw an accident where lorry e-brake and rear car slammed into it.
BigMonkey
practice the same as split road, tap brake and slow down before give way line, motorist behind should be aware, provided they are not on their phone.
EJB
Issue is some people too zealous... fast and yet can't clear the box so e-brake, they should just pass and let the car behind stop instead. That's why this mandatory give way to bus thing is really a troublemaker.
snowdrop05
Yes the give way box is an accident waiting to happen.
EJB
Granted there are some bus drivers who use brains too, don't signal and accelerate out, there are some who just do that, causing cars to abruptly come to a stop or swerve.
