KaiserBreath
- Feb 22, 2005
Hi all,
given the following code:
using ThreadVector = std::vector<std::thread>;
ThreadVector tv;
class MyThread
public:
struct MyData
MyData()
bj(nullptr), done(true){}
Movement* obj;
bool done;
int gg = 10;
MyThread()
auto th = std::thread(&MyThread::Update, this, std::ref(myData));
tv.push_back(std::move(th));
void Update(MyData data)
while (1)
// Here still uses old values....
std::this_thread::sleep_for(std::chrono::seconds(2));
std::cout << myData.gg << std::endl;
bool Replace(Movement* theobj, int newNum)
if (myData.done)
myData.gg = newNum;
myData.obj = theobj;
myData.done = false;
return true;
return false;
MyData myData;
There is a problem where std::ref is not working. When I call the Replace function from the main thread, running the Update function still uses the old default values. Any ideas?
Thanks.
ThreadVector tv;
class MyThread
public:
struct MyData
MyData()
bj(nullptr), done(true){}Movement* obj;
bool done;
int gg = 10;
MyThread()
while (1)
if (myData.done)
myData.gg = newNum;
return true;
return false;
MyData myData;
Thanks.
