Can help understand
apathetica
Got this from syfe:
Return and risk
If you held this portfolio for the last 15 years then you would have seen an annualized return of 9.68%. For comparison, its benchmark Morningstar portfolio had an annualized return of 9.29%, or about 4% lower return.
Why is it 4% lower return?
tesarise
Ok that is really a funny way of presenting.
i think thats the standard way to present ba? either like this or basis points difference.
personally i think this way is a more accurate representation of the performance difference
Mecisteus
I don't think it's a standard. I may be wrong though.
9.29% pa is 4% lower returns than 9.68% pa.
Don't you find it weird mathematically?
tesarise
i see wrongly. yes you are correct, that is not the correct way to calc.
lets say 10k invested in both portfolios.
Portfolio A gives you 9.68% returns = 10968
Portfolio B gives you 9.29% returns = 10929
10968 is only 0.35% higher than 10929
celtosaxon
Any return % is always based on the principle, not the return itself. Comparing returns is always one return % minus the other return %. Let’s look at a simple example:
Investment #1 -
$1,000 principle
$100 gain (10%)
$1,100 ending balance
Investment #2 -
$1,000 principle
$110 gain (11%)
$1,110 ending balance
Did investment #2 make 10% more or 1% more? The answer is obvious.
