Can't Power on Desktop
Ryuken_rukawa
(Solved) Can't Power on Desktop
Hi all,
I have a 2-3 years old desktop with the following specs:
1) Maximus VI Impact
2) Intel 4770K
3) G.SKILL F3-2666C11D-16GTXD
4) Gigabyte G1 Gaming 970GTX
5) Corsair AX860i
I've been using it with no issue(s) up to yesterday when I tried to power it on after coming back from a 4 days holiday.
Upon turning on the power, it is evident that my devices that were connected via USB were charging and the the lights on my motherboard were on.
However, I was unable to power it on via the casing or the motherboard.
I suspect the motherboard or the PSU to be faulty, however, cannot be 100% sure.
Hence, I hope to seek some help with regards to the problem I am currently facing.
Thank you very much :)
Edited: Found the issue (Solved)
Moderator: Please help to delete the thread. Thank you!
Blindaim
Is the cable to your monitor loose? Please unplug and reconnect them again.
Ryuken_rukawa
Hey man.
Nope, don't think that it's due to that as nothing happens when I try to power on the desktop (i.e. fans not moving, no lights from power button).
Thanks anyway :)
jtjt00
Suspect PSU dying, try jump start and see if work. If so, something short-circuited prevent the PSU from power up.
Ryuken_rukawa
You're right!
I've just sent in for RMA but sadly they don't have any stock at the moment so I've gotta wait.
Thanks for your help!
Ryuken_rukawa
How long have u waited already bro?
The guy told me that it's been >3 months since stocks for model came in. I didn't wanna accept a downgrade to a cheaper model, hence, I accepted to wait till an identical model arrives.
If its corbell, the previous two times that I went to RMA they never have stock. (x-series and platinum series)
jtjt00
Yup. No stock and sent me back empty-handed sadly :(
Just gotta do with my work laptop for now.
It's Convergent in my case. Haha
You should head down to SLS to hoot a Seasonic Prime 850w Platinum or Titanium to get your rig running. Sell your RMA unit upon return.
Me: ex-Corsair PSU users too, need RMA at 2nd year too.
