Car Vibrate when idle
viosATwork
Wow thanks. Is there any car workshop which i can go for checking or installing if I buy from stockist?
Just went for 120k servicing at autosavers. They say the engine mounting is ok =.=
yanbros
Any workshop should be able to check for you. But if you want cheap, can buy from stockist and install in jb.
trd2970
120K u changed engine mounting before? It's normally about time to change at that mileage. The mounting is not very costly it's the labor charges that kill, hence yanbros's excellent suggestion of going JB to fix.
focus1974
then car brake screeches when i brake ...
what does that mean? need to change brakes? Or is it brake too tight?
doody_
Might be brake pads worn out. They place some metal bits in brake pads as a wear indicator, so when you start to hear them screeching against the rotor it means it's time to get new ones.
Spee_Dy
Can be rotors and brake pad uneven wear as well.
Happened to mine before.
Went to skim the rotors and pads then everything ok liao.
newcell
Learn new thing,
Car idle vibrating can oso from rotors/brake pads.
