Case fan not spinning
xcrozx
Hi,
Its been around 2weeks since I got my coolermaster haf 912 advance case and recently the top fan stopped spinning. The font and back fan still spins.
Anyone have any idea how I can fix this?
royfrosty
Hi,
If it is connected via mobo, your mobo might not be supplying power to the fan. Take a multimeter and test the connector if there is incoming 12v. If yes most likely your fan is faulty. If not means mobo got prob.
If it is connected via PSU molex, check the molex got 12v. If yes means fan faulty. If no means PSU wire got prob
xcrozx
Thanks for your reply, silly me did not check if the fan was actually plugged in. Not sure how it got unplugged, but after plugging it to the mobo it is working fine.
