Case fan recommendation please!
manisherx
Any good and quiet case fan to recommend?
Good as in good air flow intake thank you!
Neptunes43
Corsair AF series or SP series (with radiators/air resistance) are good ones.
Their ML series are good too, but they're more expensive
Thermaltake riing and flo series aren't too bad
+1 to Gentle typhoon. Jetflo is not bad too.
Noctua NF series is probably one of the best, if not the best. That said, it is expensive.
Godeau
Depends on where you are installing them and whether you need pwm control...
Gentle typhoons if you don't need any led lighting
TT Riings are very nice too
Noctua vomit fans, take your pick. They introduced some coloured ones too, not too long ago
Corsair ML if you wanna try something different, but they are way overpriced
myzzy1
i bought 4x aegos 120mm off taobao.
rgb, 1300rpm.
total cost 35 sgd.
gld998
I rather get the cheapo 3pin fan and a fan controller. Go spend hundreds on your case fans
