Case for Ipad Mini
nauhchop
which is slimmer and lighter in comparison? joy black or essensual by Uniq? thanks
Sorry, I am using essensual by Uniq. Based on the pictures of joy black and my own essensual, essensual is slimmer. and the whole casing is very light too.
Cost for me is $35 and I think cheaper than the smart cover combo of front plus back cover. This is until JB come out with nicer and cheaper 3rd party cases. :o
kalasala
Any other choices like the IPad smart case? Looks great!
Get a original apple smart cover at $54 - 10% discount and Gear 4 Thin Ice back cover that fix perfect with the apple smart cover at $35-15% discount.
Provided you purchase your ipad mini at harvey norman. This is their current promotion till end of this month.
nauhchop
The accessories are 20% of the cost of the iPad. I basically dun think its worth to spend more than 10% of it.
skipper
personal preference i think,if that is the case better to use it naked,0% spend and most worth it.
bockscar
anyone knows where I can get this? Joy Factory Smart Fit
cspotato
I saw tunewear eggshell clear for ipad mini at best denki... so those who wants a clear back case can consider this as well... too bad I already gotten joyfactory smartsuit...
nauhchop
There are people who buy LV pouch for ipad and iphones. To me that is overkill. I know its branded but the cost of these pouches are equivalent to almost half or 80% of the gadget price.
The basis of casing should be on protection and light weight.
Honestly 3rd party casing from JB can do the job except that it does not have as much variety at the initial stage. :o
ml2spin
Bought screen protector $12 and Clasy case $22 from adix82 at Burlington. Good enough for the price which is way less than whatever discounts and promotions for cases when buying a iPad mini.
cutiedoggy92
which best? how much is it? didnt see at imm best leh :(
limitation
I got this case expensive $64 at Raffles. But nice!
Hey bro, mind sharing which shop at Raffles did u buy ur spigen hardbook casing? Was looking to buy a black color one..went orchard area and pop by a few shops..but they dun carry tis cover..
drpanda
I got my casing from Belkin brand. i like the jean's material casing very much... lol..
DARTHNERD
it seems that all back covers now in the market dun have the 'magnet' feature to work with Apple's SMART COVER..
Go to 1.19 to see the magnet feature..
bockscar
Apple's Smart Cover gets dirty really easily.
Tried cleaning with dishwashing soap like some have suggested but still dirty.
If die die wanna get smart cover buy those 3rd party brands better. After a few months if dirty, throw away also can.
htngwilliam
Guys,
At last, I bought a great cover at challenger today. The item is call X-Doria smart jacket. The back case is made of polycarbonate and has some uneven texture for better grip. The front is like apple Smart Cover and has the autosleep and wake function.
This case is pretty light as well and it cost $49.90. If you are a challenger member, you get 10% off..
X-Doria
