cases for CIEM
frekedech
I have 3 of it. Just confirmed they are going at S$28.
Thats reasonable. I may get it soon then... Hopefully its easier to store inside, the fitear cable is so naughty!
Anyway, I thought I'm the only one OCD putting a 'sanitary pad' inside the case =:p Cheers!
farron111
Pelican should be sufficient le.
Unless you are feeling rich then you can customize your own box like this lo
doki81
The FitEar pouch.
Price wise, please enquire with Jaben. IIRC it should cost not more than $30
Extremely durable and shock proof. Pelican cases are way too bulky for me.
ouch...i think Jaben see me look like carrot....then they sell 38 to me :(
Taeyeonie
I all 3 for free though. They "Usually" gives one for free upon purchasing of a fitear TG334/Custom.
I looking for case now like the Fitear case can coil the cable.... but I want the pelican kind hard case.... remember seeing something like that. .. anybody knows?
Ps I want to fit my Ciems and my X5 in it
Legend2127
I used to use pelican 1010 for my ciem, later I changed to UE tf10 tin case... More practical... The 1010 became my rwak100 dry box... Hahaha...
rickysio
Actually looks pretty good, but I doubt the guide will comfortably fit aftermarket cables hahaha.
Narukura
Pelican 1010. Can get from Black Technology at Bugis+ (just outside cinema), Jaben have also (but I don't like the hippo sticker on it, not sure if what they sells got also), Soundwave also carries them. Should be around $20+.
Sent from Samsung SM-N9005 using GAGT
xuan87
Hmm there seems to be ample room around the guide for the thicker aftermarket cables. Should be able to fit most but the thickest aftermarket cable. Interested in getting one to try. Price is reasonable at under S$20
vernon_wmk
There's still quite abit of room after coiling noble's stock cable. Not sure about aftermarket cables.
Preferred it to fitear case as the iems are seperated nicely and does not get tangled up with the cable and is quite abit cheaper.
Dunno where to get in sg though.
xuan87
want to order 1020 from amazon, 1010 a bit small if use aftermarket cable
1010 should be able to fit CIEM with the aftermarket cables quite comfortably BUT the main worry for me will be the depth, whether it will be deep enough to seat the ciem units.
