Casing Fan recommendation !
mehmeh91
As above , any recommendation for casing fans ( 120mm or 140mm or 180mm)?
Preferably Performance over silent
Will be mounting it on top of the case
Budget about 20 to 30 each :s22:
Thanks:s12:
tenzine
Have Fractal Design 180mm fan bought from Amazon that I cannot use as mounting hole distance is 165mm while I need 155mm. This is a top mounted fan in some Fractal Design case and moves a lot of air. Will this fit your case?
KingJio
Performance over silence? Akasa Viper. Good balance of both would be noctua. Get the industrial ver. frm amazon
ZawLee
180mm silverstone fan. Good airflow. Can see mini tornado when you set max speed.
EienShouko
Is importing a choice?
If it is, Noiseblocker eloops or Gentle Typhoon AP12/13/14/15 make great fans.
If importing is not a choice, try coolermaster Jetflos.
