casing with built in hot-swap drive dock?
nez
Medium Tower casing with built in hot-swap drive dock accessible from the front?
Recommend casing with built in hot-swap drive dock accessible from the front of casing.
Something similar to cosair 800D but preferably a medium tower instead.
Thanks
coyote
Swiftbladez
Those bays costs ~$20. You can get them and simply install them into your 5.25" bays. Get whatever case you like.
coyote
These so called "docks" are nothing more than just some mechanical parts plus a sata power & sata connector. Definitely not worth the S$19 I paid for them. Though, I have many of them in many of my PC as they are just very handy.
Let alone getting a 'sophisticated' chassis that boast about having "docking" capability & charge an arm and a leg for them.
Anyway, just a suggestion.
t258jgn
This type can?
If ITX got this
sst-ds380-05.jpg~original
coyote
The full size chassis needs to open up the side panel to access the harddisk. That's not so "hot-swap" as such racks were meant to be.
I like the ITX one. Though, so far only 1 AMD ITX board has that many SATA ports. :D:s13:
This type can?
If ITX got this
haylui
Thermaltake level 10gts
4 external hot swap bay with lock.
Need some pic?
nez
:o
Perhaps i miss out 1 crucial criteria which is for the dock to be accessible from the front of casing like the 800D.
Reason being my casing is inside a cabinet so I can swap the drive without dismantling all the cables, take the casing out of the cabinet, remove the side panel....
Hope you guys get what i mean & why as well.
nez
Need some pic?
Thanks i will look into it. It is available locally?
edit
Nevermind, Just checked that it is accessible from the side.
nez
Thanks for the advise. Its really for the convenience.
nez
Some examples to better understand what u mean by front access.
I also would prefer built-in instead of DIY if possible
Although this casing is hideous, I like that their hot swapped access is at the front
nez
Both cases only has a single hot swap bay
They are really hard to find simply because you can get any case that you like and convert the 5.25 bay to a hot swap bay, no reason for them to implement it in their design
Thanks for the recommendation. I have previously looked at them already.
However, honestly I am very, very amazed by their limiting design options for front loading HDD, much less even having them hot-swapped.
Its like a common template among casing designers. *facepalm*
nez
And to add on, from what i have seen (no disrespect to multiple fan lovers or watercooling users), casing designs seems to focus largely on the following:-
1) getting as much air/ventilation into & out of the case
2) increasing the number of holes to allow for various watercooling tubing to pass through
That is it. Period
Honestly *facepalm*
