Ceiling fan for outside?
FreSch
Have a ceiling fan installed outside, but it's gotten rusty and is almost breaking soon. Looking to replace.
Can't find any info online about fans that work well outside, and certainly not for SG climate. Any recommendations?
My only requirements are that it has a light and won't rust or anything over years of use. It's not too well protected against occasional wind/rain splashes however.
Remote control, timers etc. I won't be using, the current fan is run via a switch in the house and that's it.
Or maybe I'm overthinking this and I can just take any fan from any shop and it'll work outside?
FreSch
also for mods pls help move this thread, not sure where to post. From other threads asking fan-related questions they were posted here? not sure. Thanks and sorry
wlcling
Indoor fans cannot be used for outside especially if got rain/splash concerns leh. Go shop ask if they have suitable outdoor fan or not
FreSch
I see listing for outdoor fan, and for ceiling fan, but not for ceiling outdoor fan. It's attached to a roof over top of a balcony
wlcling
I also dunno how to see which is 'suitable'.. but many years ago, one shop recommended me use relite petite 36" for balcony. So i used for >5yrs no issue.... and wind was pretty good too
Cheap too šŸ˜†
This brand supposedly alot of retail cafes use
FreSch
Cheap too šŸ˜†
I'll take a look, thanks
KcSpider
For outdoors, especially if close to seaside, steel will rust fast
Get epoxy-coated aluminium fans, or anything that is "weather resistant"
I have no outside fans but this is what I know
FreSch
Lucky is not near the coast. But yeah I'll keep an eye out for the materials. I think mine was normal aluminium with paint, so how it rusted is beyond me
FreSch
Cheap too šŸ˜†
just checked - it doesn't have a light.
It's close though. Need to find one that has a light.
Annoying that most fans I see have many unnecessary features like 10 speed motors, reversible rotation, remote/app control etc.
Not to mention they're either ABS or aluminum, which aren't for outdoor use.
wlcling
Yeah outdoor ceiling fans seem to be limited.. but u can call up a few shops to ask what they carry then dd from there.
Aaron Tan
test
andyhtc
Suspended
Metal parts on the casing, bearings and circuit boards will definitely rust. Plastic parts will harden and crack.
Regular cleaning and maintenance will increase the lifespan to a limited extend.
FreSch
I was just told that I should find one that's on the cheaper side. Current fan I have is not made for outside, still works but is really rusted and brown.
andyhtc
Suspended
If the bearings are still good, I suggest a good cleaning, polishing, and some oiling will do.
New ones will rust again and it is a waste of money to keep changing.
FreSch
Iirc the fan is around 10 years old or older alr.
Not sure how long it'll hold up.
standarture
Don't use ceiling fans. Use standing fans. Far superior. You can cover it too.
