pohu
- Jul 23, 2000
Facing the following issues using the said telco
1) unable to connect, having this msg "The M1 number you dialled is not in work, please check the number and dial again later"
2) The phone used is those non smartphone type (meant for seniors)
3) Tried to set the phone to manual selection instead of auto selection to stay on 4G network, still encountered the problem mentioned in (1).
4) the SIM card already changed
5) the shop said there's nothing they can do when there is no issue with the phone when brought to their shop
What could likely be the issue? (Phone or network)
The easy way out could be to change to a smartphone but the issue here is the user is not gadget-savvy and has been resistant to using a smartphone.
