Changing Car Battery
digisales
Hi all! where do you normally change your car battery? which brand are you using now and do you recommend it?
EJB
Where there are workshops that change car batteries. You do realise different cars require different batteries and not all cars can use the same batteries?
You doing a survey issit?
digisales
lol. just checking if any bros have good recommendation of places to change. different cars uses different sizes, but i guess brands eg. Amaron or others can be recommended based on experience?
i am currently on the brand Rocket, not sure if anybody heard of it before.
sinistral
Don't think need to compare workshops, not like one replaces battery better than the other in terms of workmanship.
Just compare brand-price. I personally will pick Bosch or GS Yuasa.
myviowner
Heard before this brand. As long it works, no worries dude.
mryongtan
different car go to different workshop.
for my jap cars I go to Guan Lee.
for my conti, I go to Khai Wah.
all depends on availability & battery types/brands you prefer.
digisales
interesting on the different workshop for different cars.
do you guys stick back to the same battery brand or will just change based on price/availability?
anybody using amaron now? is it still as lasting as last time?
renfred89
actually in terms of brands, I prefer Bosch or Varta. Amaron probably cheaper but won't deliver consistent performance..
digisales
1 year odd, under 1.5yrs. during my regular servicing, they check the battery health and told me not optimal already.
digisales
i heard recently Amaron dont last as long as before already. so looking out to see what other options are there
another bro above also recommend Bosch
really_noob
Agreed. My Amaron changed last year, lasted 13 months, died last week. Best part is sent for servicing last month, they tested and it was still ok.
Now on Gsyuasa. Made in Japan.
eD|t|0n
Using Varta brand battery….changed twice already. So far so good, no problem during usage (+-18months) before changing. So quite happy with it. Dont really like unpleasant surprises so diligently keep track of the change cycle.
digisales
seems like the average lifespan of the battery is about 1.5years now. still remember my batteries used to last 2+ years.
afew recommendations for Varta.
anybody heard or tried Energizer? saw it on shopee
sunsetbay
Moderator
Moderator
did you change back to the same Ah rating battery~?
