Charging with ipad charger
xmen
I read that the iphone 6 plus can be fully charged faster by using the ipad adaptor rather than the default iphone one.
But will it damage the phone over time?
phayze
Phone will have no problem. Only battery capacity will decrease with each charging.
PetPet
Moderator
Moderator
Charge with it all day everyday.
No issues here.
In fact, if you're charging it via your Mac, it'll automatically churn out 2.1A for the 6
fade_white
if it hits negative, does it mean if you connect your iphone to other device, the iphone will charge that other device? :O
phayze
So far i know that no rechargable batteries can maintain same capacity with each charge. Each charge will decrease its capacity a little. Li-pol will last 300-400 charge cycle.
Even he use the original charger that come with iPhone, it is also the same. The phone will decide how much current to draw, unless the phone draw more than the charger current output, then it is limited by the charger.
No issues here.
PetPet
Moderator
Moderator
Ah, of course. I misinterpreted what you were trying to say, I thought you were saying that the iPad charger would cause the iPhone battery diminish faster.
Windowlover
Using this method for charging since Iphone 4,, afterall it is same USB connection from Apple and slightly higher Ampere is no issue. :)
tjkb230
It will draw 1A with no issue. Seen reports that it can draw more than 1A if 6+ is being used intensively, e.g. game.
So you can use whatever combination you want, more importantly is voltage. They must match...
