Chassis fan noisy
nexusRAGER
So i got a Gentle Typhoon 120mm used for about 2-3 years recently it is creating alot noise, any solutions for it? I tried dropping the speed already and the noise is still there.
Thanks in advance.
peterchan75
I tried old and grease. Oil only lasted a few days and the noice came back. High temp grease lasted a few weeks. Don't waste the effort, just get a new fan.
nexusRAGER
Luckily i got some spare fans, oh well looks like time to change
stylechap
Lubricant is useless if there's metal deposits
See if its feasible to change the bearing or flush with lighter fluid(provided its not fully sealed)
