Chassis USB Port issue
Papermoon
Hi, got my casing today and realised that the front 2 usb port, 1 of the usb port is higher so I cant plug in my usb cable. How to fix?
ZrE0_Cha0s
which chassis is that? got picture to see? kinda dun understand what u mean though...
Papermoon
It's an Phanteks Enthoo Evolv ATX Tempered Glass. The right port is abit higher such that I can plug in my cable because the hole is blocked by the panel of the chassis.
MD8l3PR
ZrE0_Cha0s
MD8l3PR
i dun get it...the hole u mean the front panel to allow u to plug the usb in?
poooooo
loosen the usb hub/pcb, realign it yourself.
if 0 diy skill, contact the distro and see what they can offer to help you, if its still under warranty.
Papermoon
Yup I did that! Thanks for telling me it's called USB Hub haha. I was searching up on misaligned usb ports and solutions and couldnt find them..
I've fixed the port already. Thanks for help all. Wondering if anyone can recommend me cheap budget cpu cooler?
