cheap 16" tyre?
Qwerrty2000
please lo... tyres got shelf life one, the quality of the rubber get degraded year by year. Even though it is new, you buy those 6 years old "new" tyres at your own risk.
i used michiline xm2 before but suffer premature crack on surface after only 2 years of use..
tankgunner
Mentor
Ts want cheap cheap tires I recommend cheap cheap ones lah.
Since he don't speed, drive short distance should be ok.
Sketchish
yup.. 3 more years to say byebye... by the way, u r great to indentify the car!:o
aiyo 3 more yrs buy good tyres lah... shld be able to last 3 yrs for a gd set of tyres... get cheap maybe 1-2 yr need changing again..
get bridgestone or conti tyres...
Enderby89
Tyre don't cheap, but if really want, scrap yard! Another option, change 2 front tyres s only, reuse good 1 and rotate for 2 back! Now you only pay for 2 front, better and safe!
pooopy
Downgrade from 215 to 195 can decrease fuel consumption
U can go sgcarmart market place to beo. Quite cheap
fat_boyz
price-wise & tiagong save fuel also?:(
crazy...compromise safety for a bit of savings...
might as well all 4 tyres use the space saving spares.... thinnest profile road legal ...
kill yourself nevermind.... dun endanger others.
zensushi
Moderator
Moderator
I've got spare tyre!
Can save on liposuction cost if you want to take it off me! :s13:
On a serious note, the workshop may be able to suggest serviceable used tyre.
Qwerrty2000
Go Malaysia change tyres lor cheaper.
but i afraid tio chop... rast time i did at jb shop, tire quoted damn cheap, but end up said moi chamber nut need to replaced, after replaced then said moi rim got slight dent so "recomend" to change woh... end up cost much more than i change it here... that was about 12 years ago...
