cheap and reliable mechanical keyboard?
MoneyFace =p
Wireless ✓
Full size X :(
Tenkeyless ✓
Mechanical ✓
LED ✓
Where is my up down left right? :(
Bardiel
also finding 1
am using razer black widow tournament edition. i need the number pad thingy.
don wanna pur so much money into keyboard. was looking at tessoro
ragnarok95
Senior Moderator
Senior Moderator
Isn't there also some mini ones with those ten keys?
Something like CM QuickFire TK...
This one not consider mini le
Mini are like what yusoffb01 posted or like like filco minila, small small one.
zephyr11
hmmmmm, just realised the mech kb i ordered are in gold frame and multicolored led.
anyone keen? will update once i get it.
Gymrat76
Can anyone recommend a mechanical keyboard for gaming + nice for typing? I'm thinking maybe Cherry MX Red or Brown, and needs to have multimedia/volume control buttons as well. Macros keys not so important and it will be nice to have backlighting for the keys, though I don't need, nor do I even have a use for 1.whatever million colors.. just simple red backlight like my current Microsoft Sidewinder keyboard is good. Thanks
yusoffb01
If you can wait, get g710 from amazon. Last black friday only $60
Gymrat76
Thanks. Thinking the Browns will be a better choice as my PC is in the bedroom and less of an audible click is a better choice not to annoy the sleeping wife! So maybe the G710+ more suitable.
Price on qoo10 now is around $200, using $10 item coupon + $30 cart coupon can get this for $140 (before $3 gift card and offset some qoo points) ~ $150
On Lazada it's $194 before Citibank 12% ($25) so $169
Black Friday a bit far away :s13:
yusoffb01
I guess thats ok since normal price is $100+ usd. But then, at that price should be able to get rgb keyboard
MoneyFace =p
Don't assume. Better head down and test them yourself. Cos what you think may turn out differently.
I would recommend Cooler Master Storm QuickFire TK with your requirement...
Gymrat76
Question on the CM. if the function keys double up as multimedia keys do I need to always press the keys in conjunction with the Fn keys to increase/lower volume?
MoneyFace =p
The answer is on their online manual...
Just like on a Laptop, pressing the FN key at the same time as any of the F1-F12 keys enables a second function programmed to this key.
By holding the FN key pressed for 3 seconds you can lock the FN key in an always on state. Pressing the FN key for 3 seconds again restores the F1-F12 keys to their default functions.
http://assets.coolermaster.com/gaming/download/keyboards/quickfire-tk/quickfiretk-user-guide-en.pdf
Dr.Vijay
Administrator
Administrator
I'm using two sets of these keyboards - one at home and one in the office.
But as with any other subjective choice, it's best to feel them in stores :)
Gymrat76
Thanks. Maybe will pop down to SLS to try, or maybe challenger :)
