Cheapest Screen Replacement for Mi Note 4
Orange123*
Hi all,
Can advise where to make budget screen replacments for Mi Note 4? This is EOl set and meant to be used as a throwaway usage, so not thinking of spend more to replace the cracked screen.. Many Thanks in Advance for your kind advice... 🙏🙏
kazuki666
I changed redmi note 4 and poco F1 at sls shop before. I vividly remember it's around $70-90, not worth imo but I did it so that I can quickly back up the data to move to another phone
Orange123*
Thanks, yes there is also breakfixit at bugis that side (red shophouse), also $80. Yes, the guy say also not worth to change the screen as the phone is really old.. but for same $80 can get better & newer low budget phone?? What model recommended?
funky05
I changed my redmi note 9s screen at jb before.. about rm160(~$50).. done within 20mins.. the shop fellow said not worth cos the phone i bought for $198 after shopee discounts and voucher.. But i needed the data.. quickly backup to another new phone.. Can feel the screen not very responsive like the original one
