Choosing a MOBO
Pepperisk
HIJACK!
Between Asus B350 Prime, GA B350 gaming 3 and MSI B350 Tomahawk, which one would you guys choose to pair with r5 1600?
FlipGor
Bump for advise :D
Are you planning to overclock to the max to squeeze out every last ounce of performance and also to run multiple gpu? If not then i dont really recommend getting a X370 board as the difference between a x370 board and a b350 board is usually in the vrms and additional features such as more pcie x8/16 or even the ability to sli.
If you just a casual overclocker and running a single gpu on a budget, i would recommend u get a decent b850 board like a asrock b850 pro4 (not b850m pro4) and save up to around 80 usd, which u could reinvest into a better gpu or other peripherals
MaoZeDuo
I am planning to oc and run 2 gpu but not at the moment due to budget constraint... Thanks for the advice... In that case... I will go for a 350 board and upgrade in the future when im ready.
For Asrock, I cannot find the price reference for B850 Pro 4... Are you referring to AB350M Pro4?
