Hi i got a old 212 evo that i want to use but its a bit dusty, the x mount has some rust on the screws already. Just want to check is it safe to use wd40 to remove the rust? of cause i will take it out from the mobo first before doing anything. Also the fins seems to have some bit of corrosion on one side, but seems quite minor, do i need to do anything to it?
