Cleaning underside / contacts of CPU?
CCCustom
Thanks for the replies. I think some of you didn't get what I meant - the Arctic Silver did get on the underside, it happened. There was just so much Arctic Silver that pushing the cloth from 1 corner to the other corner gave me a huge ball of the thermal compound when I reached the other corner, that it touched the underside of the chip. And this was only 1 side ... I had to repeat this 4 times for 4 sides of the chip.
I would have taken a picture of my fingers after I was done with it, but they were covered in so much Arctic Silver I didn't want to get any of it on my phone :s8:
Anyways, I am familiar with how to clean the top / IHS side of a CPU and how to apply thermal compound (I'm an MX4 person btw). It's just the underside / contacts part that I've never had to worry about before.
kandinsky
Wah, the previous owner making CPU sandwich, bua until so gao :s13:
Saw this video, don't know if it's a good method:
shiodong
i'm wondering is it ok to soak the cpu in isoP alcohol for some time before cleaning off the paste? to me, cpu is like waterproofed enough.
monikernemo
Very unadvisable I think.
However IMO you can soak electronic products in water but make sure before using it, there is no sign of moisture. Someone left his laptop under rain and managed to savage it.
Wongpk
Bought a motherboard + CPU 2nd hand, HSF was still on, and I took it out when I got home to find this :
When this picture was taken I'd already cleaned off the centre area of the IHS to look at the S-Spec and country of manufacture, but you should still be able to see that the entire IHS and even the latch (top and underside, no I'm not kidding) were coated with a thick layer of Arctic Silver ... it felt as if the previous owner used the entire syringe in a single application :eek:
Appreciate the advice.
you got a very good 3rd generation motherboard too bad the CPU is gone case
Maeda_Toshiie
There is supposed to be a seal between the IHS and the PCB, but it may not be 100% sealed (seal is obviously ineffective or nonexistent for delidded CPUs). The last think you need is to have moisture to seep under the IHS...
