clicking noise from PSU
wongminmin
Clicking noise from PSU, do i need to replace asap or just heckcare until it die?
Currently using Seasonic M12II,
should i buy Seasonic or Superflower Leadex?
singupingu
There's a Chinese saying to this:
Old one don't go, new one don't come.
:s13:
Sent from OnePlus ONEPLUS A3003 using GAGT
Molely
maybe its a sign already.
change the PSU better.
a cheap replacement will go a long way.
wongminmin
yeah sound like circuit popping over dying fan.
which 1 to choose...:s11:
superflower reliable for 5 years anot?
Seasonic S12II-620 $105 82 %, 85 % 82 %
SeaSonic M12II 620 $119 82 %, 85 % 82 %
Superflower Leadex Gold 90+ Full Modular 550W $109 90%, 92%, 89%
singupingu
Superflower Leadex Gold anytime any day. Now on sales on Lazada. I'd grab that if I'm you.
tigerwoods
https://forums.hardwarezone.com.sg/...p-psu-should-i-buy-5791332.html#post113279841
msaz
clicking sound from psu? unplug and never plug in again. signs of active sparks.fire hazard liao.been fixing pcs for 15 years . i have seen telltale sounds like that is confirm uplorry
wongminmin
nv see spark tho.
i smell burning...but no clicking sound yet. Then the next day on, got the clicking sound liao. After 3 days, the clicking sound less noisy tho.
The voltage supply pretty stable,can maintain but doesn't get to 12V.
Come to think of it... after dissemble, i saw white substances/glue like spider web on the coil etc....?
robolee
nv see spark tho.
that mean something burst liao. my last PSU also like that then die shortly
singupingu
Capacitor uplorry. Normal scenario for aged PSU.
commach
nv see spark tho.
Are you sure you know what's the white glue like substances are?
Nothing to do with burst or bloated capacitors or other electronic components in the PSU. The white rubbery glue is there to hold the inductor to prevent vibration which result in whinning noises, a typical and necessary procedure for vertical mount inductor.
tigerwoods
Finally bought this , working great so far. $79
