Compact and Slide M-ATX Case
kawaii_boy
I'm looking for a M-ATX Case that are slim and small in size. It's must able house a Normal Profile Graphics Card. What are available option do we have? :)
LesterQ
You should take a walk at SLS and judge for yourself actually.. :s8:
Difficult to recommend things such as cases and even worse is Criteria based cases..
Cheap : ::::::::::IN WIN::::::::::
If you do not have budget can look at Lian li or silverstone also..
Shutterbox
I've been scrolling through pages for this.
It depends on what you want.
1) do you need to mount
a) slot type ODD?
b) normal type ODD?
2) do you wan flat desktop type or tower type?
3) what number of storage drives slots do you need?
4) Do you want to use Small form factor PSU or normal size PSU?
5) whats your budget?
LesterQ
a) slot type ODD?
b) normal type ODD?
Most impt factor.
kawaii_boy
Budget $150
No need ODD
Either Tower or Flat
One 2.5 Inch SSD HDD
AMD R270X - Normal Profile
Normal Size PSU
Got such CASING exist ? :).
a) slot type ODD?
b) normal type ODD?
Shutterbox
Budget $150
No need ODD
Normal Size PSU
Got.
check out silvestone TJ08E, Lian Li V series casings, jonsbo U3, S1 or G3
chong
Budget $150
No need ODD
Normal Size PSU
Silverstone SG09 or SG10.
Can use giant heatsinks, watercooling and dual GPU.
Ray1026
just got CM N200 which can fix a liguid. not afraid it too hot lo~~
