Does compatible laptop battery work the same as original?
I mean as in the laptop recognize the compatible, show the
battery level, showing the battery is charging?
I just bought a compatible battery for my Acer laptop and
it can boot the laptop but show as 'Unknown remaining' at
windows task bar.
Plug in adapter and it show "Plug in but not charging'.
The compatible battery not compatible at all or faulty?
Any advise? Thanks.
windows task bar.
Any advise? Thanks.
