eyz
- Jul 10, 2002
Hi,
tried asking for some components recommendation in one of the existing thread, but wasn't getting any good response. Hence, created a new thread.
I am intending to a building a HTPC, mainly for XBMC.
I am a little torn between going Ivy Bridge or Haswell, as Haswell seems to have some issues.
1) Mobo+chip combo:
i. Haswell: Gigabyte GA-H87N-wifi ITX & i3-4130 (Available locally at 306$SG)
Intel Core i3-4130, Antec ISK 110 VESA - System Build - PCPartPicker
ii. Ivy Bridge: Gigabyte GA-H77N-wifi ITX (163$SG) & i3-3245 (146$US) or i3-3225 (140$US), which would be shipped free from from Amazon
Can't seem to get any Ivy Bridge CPU with Intel HD4000 locally, except from http://sg.mouser.com/ProductDetail/...=/ha2pyFaduiS1S3xrXVHY/tXaHoIMmCaStS4B5VzJBw=, which is already EOL.
Intel Core i3-3245, Antec ISK 110 VESA - System Build - PCPartPicker
2) Casing & PSU: Antec ISK 110 VESA, 90W
3) Memory: 4/8GB of Kingston HyperX Plug and Play or the recommended G.Skill
4) HDD: SSD from Amazon, depending on any good deal.
My main concern is the power supply might not be enough for the setup. Both setup exceed the casing 90W supply. And it seems that the Kingston ram voltage is not suitable for ITX mobo, as indicated on the footnote of setup 1.
Furthermore, from what I had read from the XBMC forum, that only Haswell managed to push out full 24fps videos, but there seem to have have compatibility issue.
Hope to hear some advice from you guys.
Thanks.
1) Mobo+chip combo:
Thanks.
