Converting to a m-atx build. Case recommendation needed!
bibu00
Hi all, I'm going to downsize my pc to a m-atx build because of some space constrain. I need a recommendation for a new case that is able to fit my current parts. The motherboard and case is the only thing I'm changing.
Soon-to-buy m-atx board
Intel i5 with cooler Master hyper 212 evo
Powercolor turboduo r9 280x
4 ram sticks 2x2 & 2x4
1 wireless pci card
Extra 2 corsair af-120 fans
Only 1 ssd. No hdd.
Case budget $200
Thanks for the advice guys :)
shadow84
If getting arc mini r2, might as well get arc midi r2. Slightly bigger which can accomodate atx mobo and has slightly more space. Prise wise, its only $139, $10 more ex than mini.
450D quite big in dimensions.
U can consider bitfenix prodigy M.
bibu00
Woo thanks guys for the recommendations. I'll go take a look :D
But it's not about the price for me. More about the size. Keep the suggestions comming!
sglords
Rosewill Legacy U3 :D but sg like don't have sian..
350D is great
rosewill u3 is rebrand of jonsbo u3
can go hunt on these shop
PCThemes
Tradepac
Mynextcom
U3 Non Window - $129
U3 Window - $139
weione
matx! i suggest 350D!
quite big for matx size mobo and decent space!
jarred1223
if you don't mind a second hand ft03 I'm considering a change in casing
bibu00
Can the hdd and odd cages on 350D be removed? I don't use any hdd
Jian19
No need remove odd cage
Just keep the front 3"5 bay cover and ur case will look great
Thehim
Make the jump to ITX, COoler master CM130 :)
I neh go see the graphic card accommodation though.
sglords
You wan can use drill to pop e pivot out
u can remove odd cage but Ur 2.5" also cannot put
