alan_walker
- Aug 24, 2019
Guy I just purchased the above casing and need advice on the fan connections.
The casing comes with a control module which is connected to the two ARGB fans. On the controller there is a cable port which is supposed to be connected to the motherboard with individual labels for gigabyte MSI and Asus. The connector for gigabyte is a three pin header while MSI and Asus is a 3pin in a 4 pin configuration. (A single concealed hole in the middle). However the motherboard I using X570 master has only 4 pins digital LED headers. Hence I connect the 3 pins from the controller to the first 3 pins of the motherboard. Upon launching fusion 2.0 the lightings of the 200mm fans doesn't synchronise. Does anybody able to help?
