Cooler
Derwent Graphite
Sorry noob question but does Noctua NH-D14 have warranty in sg?
Also my i5-3570k idle temps are about 50 degrees celsius at stock (no OC). Currently using the intel cooler as well, HAF 932 with stock fans. Front/side intake, back/top exhaust. Is this okay? Ambient about 28 degrees.
tuckloong
my idle ish 39-40 wo...did u disable EIST or u overclocked your proc de?
laser168
of cos there is warranty. how long is your thermal paste already? if it's has been quite a while re apply it to mx4, if you wan better cooler maybe a h80i or h100i
Derwent Graphite
nod nod...ur temp is 10 degrees higher than mine...maybe u can reinstall the fan and see if the temp drops?
I think if I want to take out the HSF I would just buy a better cooler for it, if not quite leh cheh. Thanks for the recommendation though :)
