CoolerMaster K282 Dust Problem
f4ll3n
Anyone can suggest improving airflow? I think the front intake fan is causing too many dust particles to fly in to my hdd area.
I'm using default front back fans that came with purchase.
The PSU fan faces downwards so no contribution to airflow within
Sent from OnePlus A0001 using GAGT
jtjt00
Your casing lack intake dust filter to reduce dust built up in casing. Check if the intake fan area can mount filter from Demciflex, Silverstone or Thermaltake?
Both Silverstone and Thermaltake filters are available at SLS shops.
f4ll3n
^thanks! i'll email them directly for advice if able to install any 3rd-party filters. this is a bad design :|
so far, i dont see any snap-hooks to remove front cover to access my front intake fan.
