Corsair 4000d Side Panel Replacement
ViLLaRox
Out of carelessness, I accidentally smashed my black Corsair 4000d tempered glass side panel into a million pieces. :vijayadmin:
Anyone know if there is any way I can get a replacement of the side panel only?
stylechap
You can try ask distro or taobao(this is acrylic)
Otherwise if you have the equipment you can make your own acrylic piece :s13:
_DeS__
Can contact Convergent direct. Should cost about $35-$45 for the glass replacement.
kankl
Hi. Sidetrack abit here. I am interested in getting this case.
May i find out from you if the side panel cracks or breaks easily?
Does the case have a HDD LED cable?
Thanks.
