Corsair LL Fans Problem
romodon10
I have 3 LL 120s that are conencted to the lighting node pro.
(Before you ask, its connected to ports 1-3 no skipping and wires are connected properly) When i built the computer, on the first few boots, fans worked fine as intended, however, suddenly 1 of the fans stopped lighting up and 1 of the fans lit up halfway.i ignored it for awhile as sometimes, it pops back. it kept working and not working. So i switched the ports around then now the 1 fan that didnt work now works and 1 fan is half lit up, switched it up again and the fan that jsut lit up now is half lit up and the one that was half lit up is now fully lit up with the last one not working. (basically its a clown fiesta)
Then i got a new hub thinking it may be the hub that is the problem, apparently its not as i get the same results with the new 6 port rgb hub.
Any suggestion or anyone having the same problems?
Goodshot
Just get noctua fan (orange type) , they r the best fan . Ever
Lil_d3viLz
Not enough juice to power the fans?
I don't think he would go for noctua fans. Especially when he chose corsair rgb fans.
kmchow98
Maybe one of the fans is problematic, causing problems to itself and affecting the other fans.
Test each fan individually and try to see if you can identify the faulty one.
KleoZy
romodon10
Update
I agree to kmchow98.. go test one fan at a time and narrow down the issue..
this is part of the reason why argb is failing..... the chances is rare but in time it will fail.
Okay this is what ive done, tested each fans individually
Fan 1: Lit up beautifully
Fan 2: Half lit
Fan 3: Half lit then after 10 seconds it lit fully with 1 LED stuck at red and 1 or 2 leds not lit but basically the fan is abt 75% lit
any suggestions?
