Corsair PSU cable kit
koroshiya8
can try performance PC or engage local freelance cable sleever....
If you keen i can intro you the guy who made my cables... now become friend friend with me le, after the incident LOL.
evq
Where is Performance PC?
The problem with Corsair is, for the 24-pin cable, the end that connects to the psu is split into 2, diff from the standard 24-pin.
Amazon does sell, the entire cable kit + the 24-pin are about USD100.
I dont mind buying from him if the cost is reasonable. ;)
koroshiya8
you mean like the one on the left in the below image (seasonic snow silent) ? then mine also split into 2... dont think it's an issue.
index.php
evq
Yeah, looks the same.
So does he take ur cables & sleeved them or he provide a new set?
Can you PM me his contact? Hope he dont burn my mobo. hahah
icydrake
Or you can try Cablemod from PerformancePC, they sell the custom cables per set de so it includes all the cables which you need. Been using theirs for my AX860i with no issues so far...mine came with cable combs as well.
