CPF Easy Info Thread. :)
zuppeur
If i already hit FRS, would i still be able to do rstu to ers?
apatheticme
No. Funds contributed under RSTU can be withdrawn at 55.
As long as its any amount above FRS.
Sent from OPPO F1s using GAGT
Technically he is right. You can't contribute more than FRS (or ERS after 55) with RSTU and the retirement sums only increase. Therefore you can never take out monies contributed via RSTU. You can, however, withdraw the money you displaced by doing RSTU.
elnewbie
There has been a lot of questions raised on RSTU recently.
May I suggest that we also look at VC contributions?
If the tax relief is not a factor, there are advantages in doing a VC contribution over a RSTU. main advantage is that all funds under VC aren't as restricted as RSTU.
Both my parents who are in their 70s are using the VC method instead of RSTU as such funds can be withdrawn in lump sum easily.
elnewbie
I am aware that as long as you reach the FRS threshold, the excess can be withdrawn. Having said that, as long as one is working, it is more likely that the majority of the SA comes from salary contributions. (Unless one did a huge RSTU contribution early on)
Anyway, have a look at my other post on VC.
As in your previous CPF statement?
I get what you mean.
Basically, you need to start investing early to take advantage of compound interest.
There are some problems with VC that makes it unattractive for me.
Firstly, a mandatory portion of VC goes into my MA, which I don't really like because I won't be able to withdraw it.
Secondly, there is a very low annual cap of VC at around $35k. For people like me who wants to invest a larger sum of money to take advantage of the compounding effect, it's not possible with VC.
Yes. I did a large deposit into RSTU early on to take advantage of the compounding effect.
Wood41
The government is smart enough to know
richer would abuse the safety & relatively high
yield of CPF .
Already 1 group wants to maximise the return & the other 'CPF-not-my-$' .
bladez87
what do you mean by the bold part?
henrylbh
