BBCWatcher
- Jun 15, 2010
No, Retirement Account creation on a member's 55th birthday is a very simple "sweep" up to the Full Retirement Sum. Dollars are drawn first from the member's Special Account then, if the Special Account is below the FRS, from the member's OA.What happens at 55, CPFB will transfer 105,600-5000=100,600 to RA., leaving 5k in OA (assuming OA has more than 5k). So u can only withdraw 5k from OA.
Withdrawals may then be possible, but there's no reservation of $5,000 in the member's Ordinary Account. The 55th birthday "sweep" stops either when the RA is funded to the Full Retirement Sum or when both SA and OA run are fully drained, whichever comes first.
No, the second part is not quite correct. With a sufficient property pledge or charge, you may be able to withdraw more from your Retirement Account from age 55+, but top ups, government grants, and interest earned stay in your Retirement Account then stream out via CPF LIFE.Before 55yo, RSTU into SA will be able to be withdrawn at 55yo if;
•u met FRS in RA - bal in SA/OA can be withdrawn
•u met BRS(pledged HDB) in RA- bal in SA/ OA can be withdrawn
It's best to consult the CPF Retirement Booklet, available here, to understand the basics of age 55+ withdrawal rules. And, to repeat, "Who cares?" You should be aspiring to have a decent or better lifetime pension from CPF, at least in this forum which is called "Money Mind," not "Poverty Mind." If you're rational and sensible, you shouldn't be planning to reduce the government's terrific pension offer. Focus on getting your future Retirement Account funded at least to the Full Retirement Sum and having plenty of other wealth (in SA/OA among other places). Don't focus on scenarios involving financial desperation and even poverty.
