Why fixed deposit?You want a fixed deposit of 4% SA which you can withdraw anytime While earning 4%.
Or you want OA of 2.5% which you can withdraw anytime.
Of course if you want to withdraw immediately, why bother doing shielding.
I believe one cannot choose to form RA with BRS but rather form RA up to FRS then pledge property to drawdown to BRS but this drawdown will be in cash and not able to be redeposited back to SA.You are right. It is for those who wish to retain as much SA as possible to earn 4% and slowly draw down SA when needed, not one shot withdraw everything.
Important to meet FRS or BRS with property pledge first.
Hopefully your OA will grow by the time you are 55 so that more OA and less SA will be used to form RA.
If you prefer to have more liquidity and have more in SA compared to higher payout from CPF life after 65, can consider pledging your property then RA can be formed with BRS.
The Agent Bank doesn't check the applicant's Available Balance. It's up to you ask them or CPFB for the Available Balance. Even if insufficient fund, you can be sure that the Agent Bank won't reject the applicationDon’t think allowed to apply more than what’s available and the entire application might just render invalid
tbh if it’s for purpose of shielding, some may forgot “known” loss of interest vs using bond fund method where can kena capital loss
what happens if insufficient funds to cover what's executed? so it just goes unfilled entirely? or they still fill partialThe Agent Bank doesn't check whether the applicant's Available Balance. It's up to you ask them or CPFB for the Available Balance. Even if insufficient fund, you can be sure that the Agent Bank won't reject the applicationI have experienced such situations when buying CPF shares in 3 instances ... (a) buying shares above my 35% stock limit (b) selling more shares than I own (c) cancelling outright the purchase of CPF shares. I only paid $5 for cancellation of shares I bought. All my three actions were deliberately executed with knowledge of the rules
Suggest you call and ask your Agent Bank for answers and then we compare answers ok?what happens if insufficient funds to cover what's executed? so it just goes unfilled entirely? or they still fill partial
nono. just curious. like i wonder what will happen.Suggest you call and ask your Agent Bank for answers and then we compare answers ok?
Each Agent Bank may have their own rules. Straight answer would be to tell you to ensure you have Available Bank before applying or the successful application will be rejected and you pay penaltynono. just curious. like i wonder what will happen.
not doubting what you say
actually isn't that why need to test the system? cause nobody knows for sureDon't know why some people like to test the system. Just follow the rules lah.
Tbills using CPF quite a new thing. My experience is ask them everything don't know. DBS say check with CPF. CPF say check with DBS. Even if CSO say something I don't know whether can believe or not.
Ok to test but not beyond the limits.actually isn't that why need to test the system? cause nobody knows for sure
I used to like to test the limits including speedingOk to test but not beyond the limits.
https://financialhorse.com/how-to-buy-singapore-treasury-bill-t-bill-using-cpf-srs-cash/
- You can just apply for the t-bill that gets issued before your birthday and matures after your birthday. and there are many options
- technically it is safer to put a comp bid of as low as 0.01% because that means you get (almost) 100% chance of 100% allocation vs non comp where it is subject to quota.
- see above
But what happens if not enough? Will it render the entire application invalid?
You put in 135k SA in non-comp when eligible amount is 90k? Have you find out what would happen if you get full allocation and and the cut-off amount is more than 90k and how much can you stomach if the COY is lower than SA rate?
but if oversub for NC, all who apply NC will be pro-rated.https://financialhorse.com/how-to-buy-singapore-treasury-bill-t-bill-using-cpf-srs-cash/
sorry, may I know if its the other way round? non-competitive bid will allocated first up to 40% of the total issuance
Aiya. Must write until got a catch. People nowadays do not believe anything at all, soWhy fixed deposit?
more like normal account no?
whereas if you apply comp bid and bid super lower. the chances of COY being what you bid for is very unlikely hence you will almost definitely get 100% allocation
huh why so complicated.oh, so by bidding 0.1% to get full allocation, the final benefit is enjoy the COY interest that is established and park the SA shielding amount safely ... now I understand, thanks.
base on the last COY 3.9%, this shielding method will lose 0.1% for 6 months and 4% for 2 months ... correct?
Enhanced method of shielding .... maybe better than T-bills shielding?
