Is node 605 a good case ?? Can gtx970 fit in ?
Hi all,
My space dun allow me to position the cpu case vertical.
I can only position it horizontally.
Can anyone recommend me a case which suit my need?
What are the dimensions u need to fit?
Anyway, can try Cooler Master Elite 361.
Length and wide not a issue but height cannot exceed 270mm
Do u need to use optical drive? If not then u can consider putting most tower casings horizontal lor.
Can meh? Wun block the air intake?
It wun be affecting that much.
Top becomes side, side becomes top.
sibei expensive also. lol
For some reason i love the Corsair Carbide Air 240.
Looks so industrial and doesn't take up much footprint.
Not sure if its something that suits your needs tho.
