CPU cooler suggestion!!
Yureak
lompang your thread.
using hwmonitor, tmpin3 @ 82 Deg and cpu 3 cores at 83 Deg, one core at 77 Deg while playing wolf new order...cpu fan max @ 3080 rpm. using stock cooler, and using gadget to set alarm @ 80 Deg. Is that norm or time to change 3rd party cooler? any recommendation? din monitor when i played bf4/tw rome 2 was ok, but alarm set at same temp.
not sure if other value relevant, systin @ 42; cputin @ 60; gpu @ 57
80 is normal. Just dont hit 90 odd above can le
b3njaminlee
Sry to bring this thread up.
Question: Let's say your com is on your desk. Dust will be collected below your com. Would it be bad to have intake from the bottom?
Even with filter...?
shadow84
If have decent filter, then its still ok. At most wash the bottom filter often lor.
Feeding air to your gpu ah?
b3njaminlee
Cause i just got mobo and k cpu to OC.
If possible to increase clock speed using the AMD program. (correct me if I cant do that)
Most prob installing a side case fan as well !
shadow84
If u gonna OC ur cpu, the msot u will use is either top or rear fan mounts for 240mm/120mm rads. What has bottom fan gt to do with ur cpu? Unless u telling me u wanna push the air upwards.. But then again, your gpu will eat that air 1st though.
b3njaminlee
What I'm trying to say is that since I can OC my cpu now. (already have h100i)
Might try to OC my gpu as well by using amd program.
So need to push more air.
shadow84
If it has good CFM, then it would be good for your gpu..
Btw, u didnt mentioned about ur gpu... only talked abt ur cpu, so i presumed u wanted to push air to your cpu from the bottom...
Noctua Fans
b3njaminlee
Paiseh :o
any good filter that i should go for? Those magnetized ?
I used to use Demiflex filters untill I fired them all and got a sexy Bosch GBL 800E.
images
PC is so much more cooling with better airflow.
Only need to blow it once every 3 months.
b3njaminlee
Sorry didn't want to create a thread. But where can i get replacement screws for h100i. Long black silver screws to mount fans to h100i
