CPU or motherboard problem?
OngHuatHuat
desktop used for 5 -6 years, heavy usage.
This morning refuse to boot, power can be on, motherboard lights on, but cpu fan turned for a while then stopped, then the computer just auto reboot.
tried removed HDD and Graphic cars, same problem persisted. Any advice on this?
if I were to get a new motherboard, should I just buy the motherboard + CPU bundle? Any recommendation?
wtfh4x
Boot looping first culprit is always ram. You try take out and try one stick by one stick, see if the behaviour changes.
OngHuatHuat
Thanks for the reply, I will try that it out later. My monitor cannot receive any signal from my GPU during the rebooting.
OngHuatHuat
Thanks, I manage to solve the problem, it turns out that ram slot number 1 and 3 are faulty, then now I am using ram slot 2 and 4
