CPU problem
When I try to open my CPU my monitor no signal and also my CPU every thing turn on got light but my keyboard and mouse got no signal no light on the keyboard and mouse
And also few day ago my computer keep screen hang so I need to keep restart the CPU to be able to use
Phen8210
It's called Computer/PC OR Desktop.. CPU is your processor.
When you tried to turn on your computer, your monitor have no signal. Inside your case the fans, leds and stuff like that are working is that right?
Try removing your ram and use eraser to clean the gold contacts.
xiaozozo
motherboard failure or HDD failure ba. PC hang and reboot bluescreen auto shutdown are all signs of HDD failure. no power to peripherals could be mobo issue.
2cents
hellspawn_one
most likely motherboard GGed.... if HDD failure, the screen will still be on, just stuck at BIOS page...
