CPU temp while playing helldivers 2
Encrypted11
If the BIOS shows 1.4V on CPU instead of 0.8-0.9v, probably C states are disabled.
Enable all C states and TVB. IA CEP and GT CEP.
Enable ultimate performance plan to have an in-OS control to “disable” power management when your thermal budget permits, when power management is needed change back to Balanced plan.
With a 4800 JEDEC based Corsair kit, I don’t think you need more than 1.2V in CPU VDD2/IMC or CPU VDDQ Voltage (not sure if these controls are locked in B board)
Also, is it me or every fan is exhausting air? Where is the push pull?
86technie
the 97deg was achieved under aircon on in the room
now idle is
i cannot add anymore fans liao
fan profile
BTW never notice your Artic freezer is 240mm version.
Opt to get Arctic freezer 360 more cooling power.
Do also ensure that the AIO fan on the unit itself is spining.
How to make it spin is under the fan setting, set to PWN.
Make sure the AIO connector is connected to CPU fan header.
matique
now idle is
fan profile
Not sure if your fans are the fancy ones where intake looks like exhaust. But if all those fans are standard configuration, your AIO is starved for air.
Have bottom fans do intake, pulling air in to feed the gpu.
Rear fan can remain as exhaust,
Your three side fans should be intake, if you plan on using your AIO rad fans as exhaust.
Additionally, ensure your pump speed is on the higher side, as the LFIII coldplate is quite dense and would benefit from higher flow.
Phen8210
yeah.. make sure your radiator is plugged into the AIO pump header.
Vanyel
bottom 3 are reverse fans, my exhaust are on rear and top
Vanyel
its plugged in there, earlier i posted my bios screen shot
Helldivers 2 is the only game giving me this kind pf temp
this PC was assembled last yr
and only recently my boys then informed me that the temp when running helldivers 2 going off the charts
they also had been playing for quite awhile already the game
only changes i made recently was change of psu and swapping their GPUs
Vanyel
was thinking to change to 360mm version also, but then i stopped to think about how much deg is it gonna reduce?
last yr when sourcing for AIO i already watched some videos and did some searching online
the differences in the top end AIOs and the bottom ones arent really huge
if the temp at 85-97deg, upgrading to more exp AIO wont really save it
anyways with the undervolting done the temp is now settled, its now 50-60+deg when running helldivers 2
now my new problem is i think the undervolting was overdone, his fps now drop to 60-70+ from 90-110+
Vanyel
bottom and the front side panels are reverse blades, i decided to waste some $$ for aesthetics when setting up last yr
reverse fans slightly more exp T_T
btw i think i totally cannot absorb what u suggested, i tonite go research abit what u wrote haha
86technie
Is not say more expensive AIO bro.
Difference between 240 and 360 cooling will be maginal better.
Cuz the radiator is longer and additional one more fan.
The way you setup looks weird also, the top is meant for 360 but you only
put 240.
Actually the 240 radiator you should put towards the end of the case.
That fan can put in front.
Most setup the radiator is place like this so hot air can escape quickly.
Not sure what case fan you are using, hopefully is not Tecware fan.
360 AIO wise there are some budget option like this Corsair new model AIO.
Around $150.
You can try with a 360 cooler like this, three fans to exhaust more hot air out than 2.
Vanyel
put 240.
Around $150.
well initially the aio was towards the rear, i just thought i swapped it around to see if it makes any difference or not haha
i bought the 240mm for my older casing last yr when i first bought the 14700kf, because the PC keeps crashing nonstop from day1
and after buying and installing, it didnt really helped, still keeps crashing
went to test change to a bigger casing from the sff casing
and it finally stopped crashing haha
didnt wanted to waste $$ buy a 360mm as crash issue fixed and i have nowhere else to put the 240mm also hence i just left it like this
anyways with the undervolting done, i dun need to do anything already isnt it?
im kinda planning to reduce the undervolting later tonite see will get better fps bo
*top 3 fans ar, got 1 stand alone normal fan lol
Vanyel
oh the frnt side panel 3fans are default with the tecware case
bottom 3 i ownself bought
fan maxed spd too low?
ragnarok95
Senior Moderator
Senior Moderator
Maybe it's game issue if this game is the only issue you have. Else, make sure your AIO pump is connected to the pump header and speed is always set to high/pwm mode. 240mm is like a high end air cooling HS, so you should be getting reasonable temp.
Vanyel
all his other games max was 80deg+, infact i dun think it even hits 70deg much for his other games
only this goddamn helldiver lol
actually im kinda inching back towards normal aircoolers already
if got issue will immediately know rather than guess here guess there aio working or not working
my other boy's PC running 7800X3D + 9070XT helldiver temp 80+
wont see 90deg, running aircoolers there
but i honestly think is the intel 14700kf hotter than normal
86technie
Do check if motherboard has any BIOS update.
As many manufacturer have release BIOS update to address Intel stability issue.
As for ASUS motherboard you can use Q-tune for Fan.
But first before you use this Q-fan Tune feature.
Press F5 reset all BIOS setting than redo again.
Memory XMP than Q-fan Tune as well as Secure boot.
Q-fan tune will adjust all the fan that is connected to the motherboard.
It's RPM and etc. profile accordingly to the type of fan.
Vanyel
the old casing where the 14700kf kept crashing
its housing the 13600kf without issue with the 9070 non xt card
mhw however is hitting 90deg more times than i care to notice and my corner in the room beginning to feel like an oven again like when the 14700kf was on it
my personal feel on temp is that bigger casing is really loads better
i have order a bigger new casing from taoabo since
