CPU temperature difference?
sad_xiaoxin
Anyone experience or know why the temperature difference when using itx case and mid tower case?
As I find it weird why when I'm using phanteks enthoo evolv itx case.. My cpu temperature is lower than using Tecware Vision mid tower case?
Both case have 2 intake and 1 exhaust. CPU Temperature difference of ~10c.
Isnt itx case suppose to be hotter due to smaller size?
singupingu
Airflow design dictate more than form factor in terms of overall temp performance. Evolv ITX is quite restrictive nonetheless, but airflow design better than Tecware Vision, where's its intake is more restrictive than the Evolv ITX.
Sent from OnePlus ONEPLUS A3003 using GAGT
sad_xiaoxin
Really? Hmm.. Still can't believe it.. Evolv itx intake had a dust filter and I place and addition filters and using air pressure fan.. Tecware Vision basically no dust filters or anything.. Using air flow fan with max cfm of 83, there's side vent at the front. Unlike tecware void which virtually has no vent for intakes.. Really perplexing..
singupingu
Maybe the airflow fan for intake is too weak? Also, amount go gap plays a part too. I'm using static pressure fans for NZXT S340 Elite, which also have restrictive intake, and my airflow is perfectly fine with acceptable temps, albeit I admit, come with a little bit of noise but I can live with that the moment I play something through the speaker and I can't hear my system anymore.
Try swapping the static pressure fans over to the vision and monitor the temps?
